Problems with lag/glitches in VOD section , TVIP605 s-boks
Shadow68
HI
I have just bought a TVIP605 s.boks with latest sw installed.
I use it in portal mode , to ******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******
All live tv channels is running smoothly, but when i play VOD channels.
4K streams or normal 1080 is no difference.
i got small glitches in video -In the portal setup, i have tr to change ms from none to 5000, no difference at all.
When i try to stream the same channels on smartiptv app on my samsung series 7 or on my phone, there is absolutely no problems
But on mobile / tv app, i use m3u8 links.
What can be the problem here ??
uriX
Hi.
Try to change buffering time.
Try to change your line password. ( Ask your reseller to da that for You).
Try to change video settings.
Run an internet speed test on your TVIP and check the speed.
Restart your internet router.
If nothing of those helps. Make a factory reset.
Shadow68
Buffer is set to 5000ms
Factory reset done.
Speedtest give me 122/58 Mbit, No jitter
I use cat6 cable.
mayame
mayame
HI
Same problem for me with rapid portal and tvip 415 se. Seems to be related to the tvip boxes. I think it started when they did firmware update from MAG to GSTB. But im not sure. I can´t find a solution either. As you say there is no problem with apps.
