Second hand MAG 322 Authentication problem
DJBLEB
Recently bought a second hand Mag 322 box and when trying to set up new service got an Authentication box appear requiring a Login and Password. Absolutely no idea what these might be can anyone help or advise. Thanks
Kielbear
95
38
kielbear
1st i´d ask the seller where you bought the box for info..
Can you return it?
If not i´d delete everything reset the box to works .. then install new software and hope the login and password feature was gone..
DJBLEB
Thanks for you response. It would appear that this cannot be returned. As I am very new to this could you explain how to achieve the process you describe in delete everything reset the box to works .. then install new software. Thanks
Kielbear
95
38
kielbear
Hi.. altho your box isn´t blocked you can use the info from this thread to reset your box and install other software...
