I have similar issue as well. Also, I use Tivimate. There is a per channel time shift though that may help. However, my question is, if you set your timezone, shouldn't all EPG be based on that time zone and adjust accordingly. It does not seem to do that; however, I am new to this. Some changes are off a few hours while others I cannot figure out how far they are off. I am thinking the EPG isn't even accurate on some channels, since I can't find the show no matter how far I adjust the time shift in either direction. Need more time with it, but any advice from the community on this would be appreciated. Logically, if you know a channel is broadcast out of X time zone, and you are in Y time zone, you determine the amount of hours different, and time shift just that channel should work....however, as stated previously, it doesn't seem to be that easy. Even easier than that, if your device knows you are in X time zone, and the service is broadcast out of Y time zone, shouldn't it just be a universal change where all channels are time shifted correctly? Still more to learn apparently.
