I have amiko ott a5 , mytv installed by default. Everything went well until it was introduced the secure mag option. Even if the secure mag option is disabled i cannot login on portal. The portal is loading half and then appear login failed. This problem is only on our portal, on others portals works fine. Someone has the same problem ? I sent a ticket but no help untill now.
Thank you
Thank you
