While you are in epg settings menu in perfect player select also update on every startup or dayli.Dude, now thinking about it..EPG's do play up at times..will adding this line fix it? I'l give it a try, thanks.Yes i had a problem resolved by ading custom User Agent line like this one:About 2 days and then you need to Update/Refresh Prefect Player or just turn it off and on again. Problem on your side?
Mozilla/5.0 (compatible; MSIE 10.0; Windows NT 6.2; Trident/6.0)
Now server thinks that im connecting from windows and everything works well !!
