Enigma2 IPTV-Player X-Streamity
helmi100
For enigma2 devices (OE2.0 / OE 2.5) a new IPTV plugin is available. I`'ve tested it and I can play every stream (Live-TV, VOD) from RAPID without any problems. On some streams even EPG is available.
Here is the download-link (I don't know, if it's allowed to post it)
You must add manually your RAPID Line in the playlist.txt file as described in the first thread. You can add several providers to this file.
bujars
Finland
for its every time SERVER NOT RESPONDING.
i have on my line in dashoard enigma2 add for XtreamTV. I have to delete from there?
marius_cz
158
235
35
Works perfect for me. Unfortunately there is no cover and information in the series section. Does anyone know how to fix this?
eltonbregu
86
80
Are U registered on that website?
The download link gets always updated on the first post. Latest version is 1.29
sigmadelta
Well, I'm writing this reply to the post so I'd have to be registered to do this, I only joined this site yesterday.
I'm having a bit of a tricky time getting IPTV set up on my zgemma h2h, so Im trying different options.
Any tips would be appreciated.
wiscel
Works very good, but is there a way to sort the favorites list? Not just the standard a-z, z-a sorting.
jocke90s
Always use servicerapporten (exteplayer3) with jedi maker plugin in Sterings.
if on dreambox/dreamos use gstreamer 8193
