Enigma2 script can not be installed and Fire TV stick is not synonymous
I have not used the app since yesterday and yet it does not work today. but I want to try to uninstall the plugin Xtream. do you think if I press diagnosis that something is reset? just seemed to me to be one piece of information.
if you use XtreamTv Plugin m3u link or autoscript not working anymore. As I know usually you cannot record IPTV channel program.
If you want to use m3u link or autoscript you need to remove the E2 MAC from dashboard then you need to change the line password.
Just sent you a pm. I only just landed 2 hours ago after 19hr of flights. I'll pop on and off depending if I get on wifi or not.
Glad it's still working for you so far.
