help req!
robanfield
Can any one give me advice as to why I can not get iptv smarters to run with nox. I did have this working but had to reload windows and now all I get is Unfortunately iptv smarters has stopped, I have reloaded programs cleared cache. I,M LOST!
Any help would be appreciated.
Many thanks.
Sense
629
451
www.sensus-tv.com
Sense
Hi there
Just tried installing it into Nox and i get the same result so not something on your end, Even tried different CPU settings but no go :)
robanfield
After numerous tries, deleting caches, uninstalling etc. I found the simple answer! There is another Smarters app, I think its the 2nd one on google play store.
I loaded that one and everything worked like a dream. I don,t know why because I always used the normal / original app with no problem.
Just checked and its call WHMCS SMARTERS its next to the original.
I hope this helps someone as it was driving me crazy.
Regards to all,
Rob
Reactions: Sense
UnripTV
208
UnripTV
I also had this problem and I wish I had read this thread long before. Thank you.:)
