Does it apply to all channels ? Do you see the Menu of the box ?Hello everyone,
I’m facing some issues with the 351, 4K channels I have only the sound without the image..
I’ve tried good quality 4K HDMI cables and changed resolution in the system..
still same issue.
Any help ?
FHD works fine only UHD channels..Does it apply to all channels ? Do you see the Menu of the box ?
I’ve tried to connect it in HDMI 1 and others too nothing changed, it seems that the software is updated ..In some rare cases you need to use the HDMI 1 or the HDMI with ARC enabled to recieve a 4K input .. However.. If you are still facing this issue after checking this it could be any number of things like a faulty HDMI cabel or the Firmware of the box not being updated..
I will try that,Changing image settings should rarely be done as it auto " negotiated " .. Hmm.. Well not sure what the issue could be then..
Maybe try a complete reset of the box ?
I have the same problem only with 4k movies in video club.I will try that,
By the way even movies vos in 4K are only in audio with black screen..
i had the same problem it was my provider something to do with codecs the films were done in i changed provider and they all work now on another serverI have the same problem only with 4k movies in video club.
Did you find any solution?
