Mag Box 349 blocking
bomberboy28
What is the fix for mag box 349 that is showing blocked by manufacturer?
Any help or advice please ?
uriX
Some IPTV vendors who sell IPTV subscriptions with TV boxes often block any changes in the box. This is often solved by making a manufacturer reset. If that is your case then you must reset your device. or if the error message is due to banned line or subscription, then you must contact your reseller!
