MAG converter to M3U
IPTV Community
Administrator
Jun 3, 2015
534
1,630
214
iptv.community
Hi Guys,
We got a lot of people with an old Mac address line,
People who bought directly from Rapid or from resellers who didn't transfer to the new dashboard.
now there is a way to get the line converted to an M3u line.
Download tool here:
Mag Converting Tool
You also need this:
JRE 1.8 required
http://www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.html
1. Enter the Provider Portal URL here. Example «http://clientportal.link:8080»
2. Enter here the MAC address of the device. Example «00:1A:79:00:00:00»
3. Click on the GO button
Than you insert the username and password in youre line:
http://clientportal.link:8080/get.php?username=123USER123&password=123PASS123&type=m3u&output=ts
And now you have a working M3u line
Talush
78
64
Milaim
Thnx Rusax.. you are the best...;);):D:D
Do you have also something to change Mag mac number from Old mag to New mag..
Alain Dubois
thank you for this tool.
When you get the m3u file, can it be used from any device, not only the MAG.
I mean: are the streams (listed in m3u file) usable from any computer, without being banned ? or will MAC adress be checked by server?
Thansk you in advance for your answer.
AD
Reactions: uriX
1,454
6,997
AD
the link you can use on many devices all over the world. Important do not use 1 account (line) on 2 devices at the same time.
pluto
first thanks for the mag converter i had it working great until this morning now if i try to convert im getting
Username: localhost
Password: ch
########### DONE ###########
is anyone else getting this
jonathan christy
Username: localhost
Password: ch
I am getting the same aswell
frencher
I tried the same process and have been using for quite a while.. but now when I try to enter both the host portal address and the mac address I get this following error..
ERROR: No Valid Account
Although the account I am using on my MAG 254 is absolutely in working order I mean valid account. What to do? I have searched so much on internet but could not get the answer???
damie2000
same error message for me
anonymouse
I tried and it successfully generates a username and password, but every time I press "GO", the password changes. Username stays the same.
Has this been blocked by the providers somehow?
