Smarters pro issue
Faceoflife
It works very well, when i loa
d the categorie of series is very fast but when i choose the serie that i want to ser i get the issue (see the screenshot)
I unstalles the app and installed it again and the same prob, i reduced the number of series, the same prob.
With movie, the app works very fast and very well
1,047
2,016
www.simpleiptv.net
do you have a valid rapid iptv subscription ? if yes, who is your reseller ? did you get in touch with him ?
1,047
2,016
www.simpleiptv.net
I need to know only the issue is from app or technical prob of the server
looks like samsung smart tv has limited cache/memory and missing codec for the vod movies/series.
try another iptv app, with a little of luck you might get the right codec installed.
Faceoflife
But if u see the screenshot, I can't load the discription of the serie not when i want to read the file
