Solution for bad connection with WLAN
PeterLang
51
17
Germany
1,047
2,016
www.simpleiptv.net
Hi Guys, it made me mad to have always 403 bad connection an my amazon box watching TV with WLAN.
I have found this adapter that brings back the LAN.
Amazon Ethernetadapter for Fire TV
I have tested it over 2 weeks wit tivimate and it works much much better and stable.
Only one setting changed: Buffer - None
Hope this helps some of you ;)
just a remark from my side, if you use Smart IPTV (siptv) app, then I cannot recommend to use this adapter cause the siptv app get confused because of different mac address switch between wifi and lan adapter settings.
for tivimiate and other apps it might be fine :)
