substitles for VOD
portugueseude
caralho69
hello
english not my first language
How to enjoy fully VOD with subtitles ( im my case in Portuguese ) ?
Any sugestions ?
thanks a lot
FiyiK
Contact for Reseller Panels
Premium Member
175
503
193
xs4iptv.xdns.pro
StarScreaM
Go to VOD Multi Subs category. Start a movie and choose the setting to change subtitle to Portuguese. (every device has different ways to access the subtitles included in movie, find yours).
portugueseude
caralho69
when using STB emu pro , there is option to choose subtitles.
So far none with any other option that the default.
Could it be due to my subscription not offering that?
UnripTV
208
UnripTV
Yes, if you for example looking in vod multi subtitles there is subtitles. the reason i asked you to use an external player is that i used encore stb and had the same problem that i could not see or change the subtitles. just a guess that you are having the same problems mate.
Reactions: isak7
