The best IPTV player for PC and Android
drm4sh
Xmtv is superior just lacks recording function and button configuration on play but nothing like or even close for smart phone where vlc android lacks too many functions and too way far from the pc version
Caffetin
30
Caffetin
I did test a lot of apps and software to use IPTV m3u.
Here are the results:
The best player for Android IPTV ( Using a normal remote control ) and PC :
The program called: Perfect Player :
Download link :
https://play.google.com/store/apps/details?id=com.niklabs.pp
For PC :
http://niklabs.com/downloads/
You may find more information about the program on http://niklabs.com
You may also make a custom designed app based on this app! :)
I totaly agree. I prefer Perfect Player over Kodi as it is very easy to use. For most people Kodi is a bit in my opinion overvelming if they just want to watch IPTV so i install Perfect Player for my customers on Fire stick.Fire stick remote is working great as you have volume control as well. Only thing is missing is VOD control as it is only posible to freez video but not rewind it but that doesnt work in Kodi either. Everything else is working ( EPG, Logos) as it should if you work on your m3u list a bit. To show you how well it is working here is video i made today.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Download link :
For PC :
It result with a good quality picture, comparing of VLC 1.9.6 ?
Caffetin
30
Caffetin
Never compared it really. It is irrelevant to me as i think IPTV is all about watching it on TV set not PC or small screen android devices. Picture quality is very good.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
In HD too ? No pixelisation or image blurring ?
Caffetin
30
Caffetin
No pixelation what so ever. Around 2:40 in video there are few German HD channel's playing just fine. Bare in mind that fire stick is not very powerfull device. Soon i will get cheap chinese quad core android box and test it. I imagine that it will work even better.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
With use HW+ ?
I suggest you to buy minix x8 h plus wich is Best
sukimops
14
I found a new android app
http://www.manyplay.de
1. just install and choose in the main menu [load/paste list]
2. in the edit field enter/paste your rapid ip tv m3u playlist link
or select a stored m3u list from your device.
3. then click the [√] button or double tap selected m3u to load
4. choose edit mode in main menu to remove unwanted channels
or open a m3u list file within a file explorer and choose manyplay to open
Caffetin
30
Caffetin
With use HW+ ?
I dont see point in getting 140+ euros android box if cheap chinese 35 euros box is doing same job. Just like saying to me buy Audi A8, it is much better than your Ford Mondeo. Of course if i had money to throw away i would know what to buy.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
With use HW+ ?
Ok you choose ;)
erkek43
erkek43
With use HW+ ?
Pls said me a good box for 35 euro what is never freezing on full hd channels.
Thanks and regards
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
With use HW+ ?
Thanks and regards
It will be difficult to find good box with this price
erkek43
erkek43
Thanks and regards
Yes i know this. It is not difficult it is impossible to find a good box for 35 euro :)
I tested fire tv stick but it is not good like mag.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Joseph KM
Nairobi
jmagochi
Hi, I have tried this Perfect Player and Actually Play perfect but most channels are playing in 4:3. Anyone knows how to force the channles play 16:9?
Caffetin
30
Caffetin
During playback click on ‘Video camera’ button – select needed video options there (aspect ratio, zoom mode, etc.) and save as default
Reactions: Joseph KM
Caffetin
30
Caffetin
I have recieved my mini mx box today and tested it with both Kodi and Perfect player. You can see in video Kodi launch and browsing thru menu is extremly fast. Some delay on switching channels but i think its due server at the moment. I dont mind that as long as there is no freezing and buffering :). As i expected full HD playing nice and smooth.All in all for 36 euros not bad.
