The best IPTV player for PC and Android
I prefer Perfect Player over Kodi for iptv. Make sure you set decoder on hardware and its working great.
Hi there,
I´m new here and thinking about to use service.
Question I have, I thinking to use Android Tronsmart Vega S89-H Box to watch IPTV and I´m not realy shure what to juse as software.
I Have using Kodi and Exodus addon configured advanced setup and it works like a sharm. Kodi or app?
Well if you have to use Kodi you have to configure it good specialy for 1080p channels, in alternative you can use Perfect Player and also GSE SMART IPTV which supports also Xtream Codes Api. To prevent buffering use bionic tcp ip with a large buffer everytime you startup your box.
Cheers
I have used Perfect Player on Android. I agree that it is one of the best you can get on Android. But its still very buggy.. If someone has a better app please comment.
Buggy? No!
You must Set Decoder to Hardware or HW+ in the Settings.
I did test a lot of apps and software to use IPTV m3u.
Here are the results:
The best player for Android IPTV ( Using a normal remote control ) and PC :
The program called: Perfect Player :
Download link :
https://play.google.com/store/apps/details?id=com.niklabs.pp
For PC :
http://niklabs.com/downloads/
You may find more information about the program on http://niklabs.com
You may also make a custom designed app based on this app! :)
THIS SOFTWARE CAN RECORD.
http://htcmeme.wixsite.com/htc-software
https://static.wixstatic.com/media/...98f_fcae3f1a730f485ea557a46607b31977~mv2.jpeg
Guys are any of these apps capable of scheduled recording? If so I will invest in an android STB
is there anybody who can tell me, if i can install "SMART IPTV" for an android box?!
Reactions: wbcmixtape
YOU CAN DOWNLOAD DEMO,ITS FOR WINDOWS.
if you want the full,you will need to donation.
only the full have epg,import m3u,fix xmltv file and more.
