The best IPTV player for PC and Android
EPG is a problem at the moment
i know been searching for better ones all morning, i have 4 listed in perfect player but it doesn't seem so use the others, it only seems to use the top one, there is an update for perfect player, fixed some bugs, you can go down the avenue of saving all your faves then finding epg for each one and asigning but that is just loads of work,lol
I did test a lot of apps and software to use IPTV m3u.
Here are the results:
The best player for Android IPTV ( Using a normal remote control ) and PC :
The program called: Perfect Player :
Download link :
https://play.google.com/store/apps/details?id=com.niklabs.pp
For PC :
http://niklabs.com/downloads/
You may find more information about the program on http://niklabs.com
You may also make a custom designed app based on this app! :)
Not recommended for Android always buffering.
Download link :
For PC :
In my experiance this is not true. Perfect player doesnt buffer at all. Working much better than Kodi, stable and very fast channel switching as long as decoder is set to hardware. Of course diferent Android boxes behaves diferently but so far i didnt experiance any problems on Fire tv stick or Nexbox a95x. Also on my phone works just great. Works just Perfect. To prove my point short video recored on my by no means high end Huawei P9 lite android phone. https://drive.google.com/file/d/0B4hePXSa_JCcd21fS1ozTkxQN0k/view?usp=sharing . Of course I can make 1 hour video to prove it doesnt buffer but take my word for it.
Download link :
For PC :
I agree with you that Perfect Player on SOME devices like cell phones and tablets working good, but on Android TVs very bad with massive issues,
And I guees the important device is that TVs is that right? I don't think most people watching IPTV on cell phone lol.
I recorded with phone becouse box i am using have not enough power to record screen. As I said "Of course diferent Android boxes behaves diferently but so far i didnt experiance any problems on Fire tv stick or Nexbox a95x. Also on my phone works just great" so I tried it on few boxes and never had issues whatsoever. If you had bad experiance with one box it doesnt mean you should keep saying that Perfect player is no good as there is many people on this forum that recomend it highly including me.
Edit: I have just seen that on your intervetion Perfect player is taken off recomended android app list from this tread https://rapidiptv.com/threads/faq-guide-to-all-new-users.4088/ . Totally unjustified
https://rapidiptv.com/threads/buffe...-channels-shows-black-screen.4134/#post-28681
Player with working sub?
I have tried on android mxq pro box: perfect player, iptv extreme, gse, mx player, vlc, wiseplay, kodi and a few other that I don't remember. On my tv siptv works only for dvb but not teletext. For example On androidbox iptv extreme show dvb sub but stuttering when showing text. Is it possible to have dvb and teletext and no stuttering on my box, rk3229 and 1/8gb? Without sub everything runs smooth and perfect player is the best I think.​
In Kodi you should not have any problem with subtitles on that box and Chipset ... The latest version of Perfect player with the updated Decoders should also work just fine.
Do you get any subtitles in Kodi ?
In kodi dvb no teletext and poor epg.
In Perfect player no teletext but dvb with hw+ but no sound. Hw runs smooth but no sub.
In mxplayer with iptv no teletext only dvb bad epg, and no sound hw+
Vlc on pc I have it all and tried in tvbox but cant get any way of choice, seem to work only with touchscreen.
Iptv extreme same as perfect player and mxplayer.
On my tv siptv no teletext.
Only solution seems to be a htpc but is there any other way. I want a simple player like perfect player on my tv box nice with remote controller.
Is there anyway to get sound, epg, dvb and teletext just launch a simple player like perfect player and use my time to watch tv instead of tweaking and looking for a solution all the time?
Another great IPTV Player: Simple IPTV Player
Download link: https://play.google.com/store/apps/details?id=thalles.org.playeriptv.com
Installs: 500,000+
Compatibility: Simple IPTV Player is IPTV standard compliant and is also compatible with XSPF, WPL, ASX and PLS Playlist standards, it also supports Android TV and Remote Control, or you can use it on your BOX TV Android without problems!
Simple IPTV Player was designed to be simple and without many tabs, because from what I saw, when we use these players with many options on Android TV or BOX TV with Remote Control is very complicated, you will not have this problem in this Simple IPTV Player!
Featured features:
Compatibility with ChromeCast Devices, Easy Connection!
❤ Put your Favorite Channels with just one tap!
A List with all recent Channels accessed (You can clean it anytime!)
A List with all recently used PlayLists (Clean when you want!)
▶ ️ Did not like Internal Player? Watch the External Player you want!
⏲️ Automatic PlayList update, you do not have to keep checking if the PlayList has been updated, the app does it for you!
✔️ Checking Online / Offline items, the system checks to see if the Channel is Online or Offline!
If you have only the direct link to the video / audio, no problem, the app is also compatible with videos and audio links!
