No probs.. don't forget to edit portal settings on your mag to point at the xtream portal.. then its job done.. your owcn channellist and a much nicer user interface I thought ... Also don't forget to do the epg-assigment for channels.. I had to manual put some in thou as the auto-assignment didnt work properly.Ah thanks, that's the step I couldn't work out, I now have the channel editor, thanks for your helpIf you click on the name you gave it under the mag portal list.. it will take you to a page with all the channels and groups.. and you can edit, disable, move channel around and edit and create your own channel list..Well, I've added the MAG device, I have been able to choose which countries I want although I see no option to edit channels. Really have no idea what I'm doing!![]()
