Hello!
Finally discovered how smart iptv is. I have in recent weeks tested a range of apps on my samsung TV (bay-iptv, smart stb, set iptv and ibo player) I have encountered a couple of problems that I simply wonder if they will solve themselves if I buy a box.
1. Program information, It does not keep up at all, times are completely wrong and on some channels there is nothing at all.
2. Is it possible to browse the channels quickly? Here you only have the choice to "hold down" the button and it is not possible to change sides smoothly.
3. Can channels be removed from the list/ reordered? Now there are duplicates of a lot thanks to hd channel or not.
So to the final question, what's a good first box to start with?
read a lot about tvip-605 and many recommend it for beginners, is that something you recommend?
Many thanks in advance!
