XCIPTV + Free VPN ! Updated Guide !! 2021
HonkHonk
@Sense
Hi mate & everyone else in this thread!
I have tried to use the tinyurl on my android box, this returned errors (either: can't download config from URL or the orvpn-no process running)
I have then used the new tinyurl on my tablet (android) which runs the xciptv app as well. This worked.
I have then proceeded to delete and re-install xciptv app on my android box. After adding the config via the new tinyurl, the app made a connection attemp (with the pop up for the connection) and then it returned the orvpn - no process running error.
I am quite frankly not sure what to do anymore. Does anyone experience something similar? Any ideas how to solve this?
MaximusRiba
Hi.
I press the botton connect but anythink happen. Dont connect vpn.
Can you help me?
geppoerfolle
Hello, i have the 5.0.1 version on fire stick, the url don't work, can i use the purevpn app in the fire stick? I'm in secure mode on?
thanks a lot
P.S i have config the iptv extreme with file .OVPN, can i use this file on xciptv vpn?
