Best player for subtitles on android
Wonak
20
Hey!
Which is the best player that support subtitles and where I can change the cache settings. Right now I'm using Kodi 17.0 and the only downside is that I found it laggy, sometimes it has low framerate on HD channels. I have a T95Z plus android box.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Hey!
I use Smart iptv on my minix, works great
Wonak
20
Hey!
Does it support subtitle and have cache settings?
I tryed that app yesterday but it didn't seem to have any settings and I couldn't find subtitles. Where did you download that app? I had to download the apk since my box didnt support it so I couldn't download it from play store. Maybe I had an old version.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Hey!
http://sip******* WARNING FRAUD **D...MIN *******/howto/android/files/SmartIPTV.apk
Wonak
20
Just tryed that app again. I can't find any settings for the cache so it just buffers, I'm afraid. Thanks for the tip anyway.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Press on Ok button and hold
Cykelkalle
24
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Reactions: Cykelkalle
Cykelkalle
24
Does swedish subtitles work for you on Smart IPTV? I tried it yesterday.
Like C more first and viasat comedy
I will have to check on my minix box further.
Btw, I saw that you were doing some kodi advanced for faster zapping and caching.
I got a Raspberry Pi3 running kodi, sometimes the channels disconnect and the zapping takes time. Running Libreelec Kodi.
You got any idea why? Or do I need to edit advancedsettings.xml?
Nevermind, that was user harrypotter
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
I can suggest you to check my thread fix buffering on rasperry device
Cykelkalle
24
Can you link it to me please?
Bvdpas
33
Netherlands
Hey!
You have audio on Netherlands channels like NPO 1, RTL 4? SD NL channels have audio on my box but HD NL doesnt work...
rokudisco
Erik M
Norway
Hello CyberKalle
subtitles doeas not work for the moment on the smart IPTV app.
They have promised a new update were it should be added.
Regards Erik M
UnripTV
208
UnripTV
I also find that IPTV Extreme Pro is the best for subtitles, and you can use VLC as external player with it if you want, both very good with subtitles. Easy to fix of sync of both sound and subtitle.
Reactions: isak7
