Can I use an STB EMU without Kodi?
L
lowfell
Hello everyone. I'm just after some info as I'm a newbie in the world of IPTV just bare with me if I'm asking stupid questions.
1. Can I just download a program like STB EMU to a firestick without using kodi ?
2. With the STB do I essentially point it to a URL that will be my IPTV provider/subscription?
3. Would my ISP send me a warning for streaming certain content if I didn't use a vpn?
F
Flipper
You can use the STBEmu app on a firestick without KODI. The way you set it up is complicated. If you have a good IPTV provider they can help you set it up. As for your ISP that depends what country you live and also depends on what other apps you have on the firestick. If you use any torrent apps you must use a good paid VPN. If no torrent apps chances are your ISP won't be looking at what you are viewing.
Verified & Trusted Super Reseller
66
23
mohamed1962
Sure you can install STB EMU on your fire TV stick (without kodi). It's easy and If you send a [P]rivate [M]essage to me, I'll send you a step by step explanation how to do so :)
H
harpdog
boogie
You will need to send you mac address that you get after set up to your provider. If you provider only allows for 1 connection you will need to purchase another connection. Changing an extreme code for a mac is not a free venture unless u purchased more conecction or you sour sub already has multiple one.
Thread starter Similar threads Forum Replies Date
R Kodi 1
V Kodi 2
Sense Kodi 39
B Kodi 0
H Kodi 3
