Channel Name: La Deux FHD BE
Problem: Channel name is now Tipik, therefore EPG is wrong for this channel.
Country: Belgium
Which type of device/ app:
Nvidia / Tivimate
Channel Name: CLUB RTL BE
Problem: No EPG
Country: Belgium
Nvidia / Tivimate
Channel Name: PLUG TV BE
Problem: No EPG
Country: Belgium
Nvidia / Tivimate
Channel Name: TVA MONTREAL HD CA
Problem: No EPG
Country: CANADA
Nvidia / Tivimate
Channel Name: Ici RDI HD CA
Problem: No EPG
Country: CANADA
Nvidia / Tivimate
Channel Name: VOO SPORT WORLD 1 FHD BE
Problem: No EPG
Country: Belgium
Nvidia / Tivimate
Channel Name: VOO SPORT WORLD 2 FHD BE
Problem: No EPG
Country: Belgium
Nvidia / Tivimate
Channel Name: ELEVEN PRO LEAGUE 1 FHD FR
Problem: No EPG
Country: Belgium
Nvidia / Tivimate
Thank you.
Come on... The country specific epg works... just the global one is broken .. 502 bad gateway... did you forget a variable somewhere?..
Hurry no fun without epg...
Country specifik EPG can be added in Tivimate so you got at least EPG in your main group of channels that you use most. Just add the xml link from dashboard and EPG will show up in the chosen country.
tech team seems to be working on it... under your dashboard you find soon an epg file for all countries.
Hi, Link should be with .gz on the end? Its not realy working on tivimate. try to change epg source for playlist but no change.
No with xml on the end. I have added one country to my Tivimate and it works fine. I had to mark the new EPG as "standard" in settings.
With this epg source in tivimate I have double information. On epg for all channels from this country is shown "movietitle:movietitle" two times the same.:confused:
I got reported too
When will you fix the ESPN dutch channels EPG.. It is available on their site and various other sites... even in the rytec EPG sources... You just need to write a proper grabber...
Now almost a year NO EPG on these channels..
