Ex-yu EPG is worng on all channels with xtream code, if I use the xml data from dashboard its correct. the problem is when you look at the epg, ther is ever the same entry from 5am to 10 pm. I reported tis moretimes over dashboard but nothing. EPG on smartiptv televizo tivimate same behavior.
EPG is on Tivimate and IPTV Smarters Pro Down someone also has a problem
All EPGs are down on Tivimate and IPTV Smarters Pro Down someone also has a problem
  • Haha
Reactions: Origin
Reactions: panamahat
