I've been helping out the in-laws with their IPTV solution, which is a Raspberry Pi 3 with Kodi, and then the Simple IPTV client. This is OK, but the ease of use isn't really there. The EPG has never worked and they use the same remote for the Pi and the TV. If they wonder off from the IPTV menu, they are in trouble.
SO, long story short - WHICH box should I get for them instead? The box must be able to connect to some kind of portal like the MAG, so one link gives them both channels, epg and logos. And the box GUI must be senior friendly.
Any suggestions? An android box or the TVIP box? I've read several news about MAG going out of service as they are trying to prohibit copyright infringement. Or is this not a case any longer?
Kind regards,
Mabbe
Kind regards,
Mabbe
