Hi My Mag box is saying blocked
roydon
Roydon
Hi My mag box is not connecting since about a week ago has the url changed as try it on a browser its the same?
Thanks for any help
roydon
Roydon
saying copyright infringement please contact your iptv prover
7,035
Seems it's a blockage from Infomir in the new version of the firmware
Please try this process:
- Factory reset the box
- Auto software update OFF (before connecting to the internet)
- DHCP update OFF (before connecting to the internet)
Beny
171
49
Switzerland
stariptv
just change your portal. maybe you have clientportal.link? ask your reseller for a other one (his one)
repoks
15
23
fucking infomir they have blocked my mag322, it says it cant connect to the internet but the internet is working. I need to try the noblock method
oliwal
Hello, sometime it's only blocking with stalker portal /c/.
Use XC Api login instead will help: Enter your portal address (without /c/), but login with username and password. If you have only stalker portal ask your reseller for user and passw
