IPTV on old IPAD air running on IOS 12.5.7
Frode Kristiansen
Are there any apps in APP store that allows running on IOS 12.5.7?
This is the latest version on my IPAD AIR. Apple don`t allow me to update to any higher version.
Origin
Metalli.co
240
472
metalli.co
weescotsman
Have you actually looked in your apple store to check ?
Or are you wanting others to check for you.
Frode Kristiansen
Yeah, I have checked many of the ones available, probably about around 8-10. They all require higher OS than I can get on my old IPAD. I was able to get an old version of Netflix by switching the the Apple id account from a friend of mine. But it was not possible to get an older version of an IPTV software with the same tactic. So far no luck. I was indeed looking for an advice by someone who had encountered the same difficulties.
DuHuifangVivian
I recommend a free IPTV player to you. It is "NBPlayer IPTV". Currently, you can download and use it on Google Play, APP Store, and Android TV.
