Hello!
I'm running a Mag 254 with latest fw update and since some weeks my iptv portal started to blink and flicker:
The portal is loading slowly. Then:
The country channel list finally appears and disappears and appears and disappears... It's difficult to select a channel and now it's more or less every time that it's not possible to even start watching TV.
The box shows a black screen and reloads the portal.... Back to the beginning.
I tried a factory reset, set up everything new, did the same for my router... Nand or Nand 2 or DNS 8888 did not help or reduce the problem.
This started some weeks ago. Maybe beginning of February it became annoying.
Did I miss something?
Thanks for support!
Thanks for support!
