MAG 410 Technical Issues
IPTV Community
Administrator
Jun 3, 2015
624
1,726
214
iptv.community
This thread is dedicated to technical question and installation tutorials regarding MAG 410.
Feel free to submit your questions and receive technical support from other community members.
giantiptv
35
johnwick
A reseller has locked down my box not to show content sources. I know for a fact that tvip 410 supports m3u but its hidden. How can I set the box s tvip 410 in to factory settings so the option will be available?
Please help me, I dont want to be stuck with the same reseller, I want to be able to choose in the future.
You can try to put M3U playlist to USB flash drive and enter path like /tmp/mnt/sda/your_playlist.m3u as M3U-playlist content source.
ripmaniamania
I did a factoryreset and now m3u is available, if you set MAG for whole system it will be stuck in this mode until you do a factory reset again so you can choose for TV Only in options then you will have to add your portal and select it each time. Its a easy config either way.
Thank you for your answer though.
pompinio
pompino
Hello everyone,
Due to the technical property of the box, I would like to use it. Do someone could provide me some tipps how to get this device works with the IPTV? Do you know if stalker 5.1 or upper is supported?
Thanks a lot in advance.
BR
The Cable guy
marchello78
Sama here i have costumers that want to get connected but no info or guide for it
dudenl
76
dudenl
1 client of my also have 410.
We couldn't get it to work with stalker... Only with m3u
Rusax
Let me show you the world
Feb 4, 2017
576
743
www.rusax.nl
Rusmir
i wil try to look into it
dont have a mag 410 so can take a while
but wil let you know
galitone
I aim to please.
Nov 14, 2016
59
17
InfernoIPTV
It's an official infomir box, comes preloaded with the Stalker middleware app. Why should it not work?
Rusax
Feb 4, 2017
576
743
www.rusax.nl
Rusmir
becaus i know in the past Rapid blocked the Stalker Middleware, becaus of safety isseus with it
dudenl
76
dudenl
Just saying it didn't work for my client... Tried it myself on the box...
It's fully Android based so installed SmartIPTV instead...
galitone
I aim to please.
Nov 14, 2016
59
17
InfernoIPTV
What are you talking about? Stalker Middleware is the portal software provided by infomir for the mag boxes? I'm fairly sure the xtream-codes stalker version is 5.1.
Rusax
Feb 4, 2017
576
743
www.rusax.nl
Rusmir
the problem lies in here
. General case.
Login - enter login;
Password - enter password;
Basic URL - enter URL to server containing Stalker Middleware portal. <<<==
rapdi doenst have a server with a Stalker middleware portal on it so you cant rederect to it
galitone
I aim to please.
Nov 14, 2016
59
17
InfernoIPTV
The MAG portal link IS the stalker middleware portal man.
Just provide the MAG portal URL, and you'll be fine.
Reactions: West Ham Pete
Talush
77
69
Milaim
You are the provider, user name and password is on your link and url is the mag portal
