MAG 410 Technical Issues
harryporter
184
45
harryportir
Yes I use Prefect Player now, but I want the stalker interface :::(
STB EMULATOR PRO is with stalker interface but as far as i know subtitles are not yet supported so if you want mag interface with subtitles you have to sell your box and buy or TVIP 412/605 or mag 254/256
Harry
rikardo42
Can you record programs with it while setting a timer and can you transfer it to a computer afterwards?
squig007
Can anyone confirm does this work on a mag 410 box without having to use the stb emulator
iptvko
Switzerland
iptv.community
iptvko
Yes it works with Smart IPTV app like with smart HUB TVs. Just download the apk and install it. Then put your Line with your MAC Adress on siptv website.
squig007
Yes but I would rather use the correct stalker software when will this be using dated so it can be used
Sandrito
IPTVexpert
61
44
Sandrito
You bought an Android-Box! You schould buy an former model like MAG-2xx or MAG-3xx with the stalker portal already installed.
squig007
The stalker portal is there this iptv isn’t compaitable with the latest stalker that’s the problem
AAMAA
the only provider supported the mag410 is Ipexpress
but stalker app in mag410 is not good better if you use STBemu
DiabinhudoPorto
i have mag 410 and for me is impossible to login with the stalker
i try a lot times with success...
is possible to have iptv for another application?
i have my normal portal that i use in a mag 250 and i want to change fot this box
is possible?
thank you
globoido
Install smartiptv app on mag410. Use sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/mylist/ Uppload m3u channel-list.
I use this and think it is way better than mag-portal.
MANSOORNYC
Dear Guyz iam having tough time to type new Portal, becasue i dont know how to remove this current Portal using remote control. iam able type but dont know which button to click on remote control to remove. I used the up and down, left and right the arrow button on remote control but still dont know how to remove this using remote control.
Please need Help
Origin
Metalli.co
241
473
metalli.co
weescotsman
change to default keyboard as your using the google one... been a while since i used the old keyboard as i use that one your using but i have wireless keyboard... let me know if you get the 410 working as i thought it was not compatible
