what portal url is working? i just get errorThe new update works on Rapid.. using stbemu
Hi Azole.. sorry i´ve not replied before this.. lot of work on at this time..
If i were you i´d delete the settings and start afresh..
open settings - apps - stbemu (pro) - open and delete clear data - open the app and you´ll have to configure a new profile - add profile - pick a name - done - ok - portal url - change to rapids url - ok - save - ---- in stb model - firmenware - i pick r19 250 - save ... in the other menues check to see if everything looks ok..
hope this works for you
Installed SmartIPTV on my MAG410 but just got error message "Failed to load a channel list from default server" with no option to configureJust saying it didn't work for my client... Tried it myself on the box...
It's fully Android based so installed SmartIPTV instead...
Is MAG410 supported via portal settings?When you configure a new profile.. you have to change the portal url and insert the url you were given.
No does not support.Is MAG410 supported via portal settings?
