MAG 410 Technical Issues
When did you try, because since 2 days is updated to 5.3
I have the Mag 410. i also wanted to run that stalker middleware, but Im using Kodi now. and it works well.
For the old panel xtreme codes there will be an update to work this box, but as the panel here is different I do not know how it works! ...
I was going to purchase the MAG410 but was told it is not compatible with this service. So I go the Dreamlink T1 Plus instead.
Hi guys, what is the difference between Mag 410 and Mag 351 and wich is better for the rapid tv service?
Can you tell me if it is possible to install Kodi on a MAG 410 and how because I can not find the software in the MAGIC STORE.
Thank you
I also have bought the MAG 410, but It don't work now.
So please can anyone tell me how I can this box work with Rapid?
Hi I´m new here.
I have the Mag410 box.
Is there anywere that I can use it with the stalker client?
Is it anyone that support the new stalker 5.3??
Hi I´m new here.
NO its not supported yet as far as i know, you must use some android app like STB EMULATOR PRO, or Perfect Player, Kodi, etc because mag 410 version is simply an android box as all others.
Harry
