I´ve asked admin to open a new section for the 351..
I received the Mag351 yesterday (11 January) and i´m disapointed in it´s performance in the 4K VOD .. films don´t run smoothly.. i´m still testing the box.. i´ll be trying out some higher quality cables and trying to adjust my router to deliver a better stream to the box stream giving priority over my other devices.
I paid 123.90€ delivered..
early evening had 34,10 MBPS using devolo.. 4K films buffering a lot but no freezing (used Predator and Mission impossible)
this morning 35,00 MBPS using Devolo ..4K films buffering a lot but no freezing (used Predator and Mission impossible)
using cable 43,92 MBPS hard wired .. better but after about 10 minutes the films started buffering (used Predator and Mission impossible)
I´ll try increasing the buffer cache in the advanced section..
but its a long progress.. increasing by 2 each time until it runs (IF) it runs smothly..
first impressions.. bit disapointed as i don´t think the box will appeal to everyone .. not just plug and play..
On a Samsung TV the resolution was 3840 x 2160 x50p
I´ll let you know if i can get the films to run smoothly
KB
