Hi all
Had a new mag 322 and updated it big mistake got the copyright warning.got the portal block.tried everything i could find on net.flashed no block firmware which was successfully it states in device info no block firmware 254.the problem is portal has disappeared under server setting.tried resetting default setting loads of times.read got to ssh with putty some setting in box setting it to 0.then flash otherwise nothing change has its locked in box.help please pref an idiots guide.
