If I want to become a sub-reseller? What are the minimum buy of credits?
And what's the difference between reseller and subreseller?
To become a sub-reseller,the minimum credit you have to buy is 200.
And the difference between a reseller and a sub-reseller is that,a reseller sells directly for rapid and a sub-reseller sells from a reseller.Which means even though a sub-reseller also sells from rapid panel,the panel is from a reseller.Hope this helps you.
Reactions: AndyX
well subreseller can start with 5o € but reseller must have min 2oo credits to create panel for sub reseller
Reactions: AndyX
Hi Guys,
I am interested in becoming a subseller.
Please can you PM me with info and prices if interested.
Thanks in advance.
JohnnyF
thank you for your interest our service.
Offer and details send you in Private Message (PM)
Hi Guys,
Thanks in advance.
Hi Guys,
Thanks in advance.
I'm interested in becoming a subseller.
Can you send me info with conditions and prices?
Hello gugs..
Im thinking of becoming a reseller (subseller) if its possible.. I have one offer from the guy im currently buying sub from. I want to see some price ideas from others first though. I believe its a bit of scaming going on.. Preferably a Scandinavian with offers but not a huge concern as long as you are willing to help with questions and suppory in the beginning..
Bless
Judge
Hello gugs..
Bless
Judge
Please can you clarify the below part of the terms and services?
Specifically, the part in bold.
3.3- Sharing a subscription
Account sharing is not permitted. You can only have one active stream open at any given time. There is no restriction on how many devices you can use your subscription on, just not at the same time. Please note sharing a subscription will result permanent suspension or device ban.However by purchasing extra connections, number of simultaneous connections will increase up to five user per each subscription.
Am I correct in understanding, that the below is what is meant.
1 sub. = 1 connection.
2 sub 1. = 2 connections per sub. 4 in total.
3 subs. = 3 connections per sub. 6 in total.
And so forth, ending with the 5th sub purchased.
Adding to my confusion, the wording is 'purchasing extra connections', does this refer to the 95% of first sub. option introduced with the new panel?
Or are we talking actual subs with seperate logins here?
I look forward to your answer.
Thanks.
Extra connections = same login and you can use it on max connections you have bought at same time.
Extra subs = different login but can only use it on 1 device at same time on each sub.
Ah right, sorry for being a bit daft here :D
I guess it means you can purchase 1 sub, with a limit of 5 devices on a sub.
Yes that's right.
I really want an alternative there you can buy extra connections for maybe 50% of main sub but only same IP allowed.
Yeah, I agree. 95% on the 2nd connection isn't very competitive.
Also, where's catchup? Buy some damn storage and activate if already ;) (other than Dave and BabyTV in the UK section)
Many US IPTV providers for example have extra connections for about $5 and some even have 3 or more as standard.
