Starters Guide for Android TV Box
3,485
You have recently purchased an Android box and are annoyed about the small user manual,
which in general isn't helpful at all,
This should assist you out hook up your device
1st. Start to connect the HDMI cable, which usually within the box.
2nd, Plugin Ethernet cable or connect to WiFi.
3rd. Plugin the Power Adaptor and start your TV (change to the chosen HDMI port)
Setup Network
Go to the Settings screen and click on Network. And select your network, Wi-Fi or Ethernet. I always recommend Ethernet cable before wifi... Especially if you’re going to watch HD, FHD or 4K channels, then you need all the power you can get.
Add your Google account
  1. From android tv's domestic screen, scroll down till you attain settings.
  2. Select Settings.
  3. Underneath “Accounts” select Add account.
  4. To sign in, enter your e-mail address and password or use your smartphone or pc.
  5. You will see a display screen that announces “success” when your account is added.
And set up that your apps update automatically whenever there’s a new version, makes the life less difficult.
Android TV box IPTV Players
Here’s a couple of tutorials & suggestions for few IPTV Players:
Now you need an IPTV Subscription/ Trial
