Tvip s-box 605
Ariian
23
26
For exampel:
Better CPU, 4K resolution, android 6.0 (415 run on 4.4, 1 gig ram and 8 gig flash (415 have 512 MB ram and 4 gig flash) and so on
Okej but is there any use of 4k since There isnt any channel/movie on rapid with it? I use mag option on my 415 and use it only for iptv. So right now it isnt worth it to change since i wont even notice a difference on it hehe. Thx for answer
Amplifier
Skåne
Amplifier22
Does anyone know if you can install like an app on a tvip 605 running linux.
I want popcorn as an app.
You can download popcorn in linux..
iptvxtrasweden
19
iptvxtrasweden
Have nr tested yet
can probably do that tomorrow
theres no download section in the meny, only to reach the web
maybe its done the same way as you provide dreambox, vu+ boxes with application
Reactions: Amplifier
Kremor
Seems like the install-menu is different to a normal TVIP 410/412. Where to put the portal-adress? :)
Ramon Chircop
Trusted
37
ilking
Hi, I have set up the 412 for a friend. I was undecided which method to use (m3u or mag). Finally I opted for the m3u because scrolling down the channel list is much easier. Using the mag system I did not find a way of scrolling down pages fast. Did anyone find this a problem too? The other thing I did not like in the mag system was the fact that all the countries were showing on the list even though I disabled them from the bouquet editor on the dashboard. Using m3u only the countries I chose appeared. I'd appreciate any help if you managed to find a way to solve these problems. Thanks.
iptvxtrasweden
19
iptvxtrasweden
It seems like the android system not activated with the firmware to tvip-s 605 (not an original), so its just running linux at the moment (setup as a portal)
I think theyll release an android firmware soon to use tje android 6.0
Lagal
Fast response and free support - paypal,btc&swish
Feb 5, 2017
47
sweden
smurferina
did u fins anything regarding swedish subs on viasat channels? or this will not be possible at all?
Kremor
Yup, TVIP having big problems to put the correct subs on some channels.
MAG works like a charm.
rokudisco
But mag cant activate teletext on channels that have that turned off for example UK movie channels, that sucks
jfjong
Hello!
As i figured out, android is not possible yet in an official release for this box, but there is a way to upgrade it to a bera version (instructions on link)
https://wiki.tvip.ru/en/how_to_update/ota
Dont know if maybe there is other way with android app to get the subtitle to work
Itäs siple to change to Androud. Just select pre-release in system menu and install. But I don't see why you would like to do that. The Android is not supported yet and frankly not realy usable. The QT Linux version is stable and works perfectly - including subtitles (on the Swedish channels, I am Swedish). You should use it in m3u mode, not stalker.
iptvxtrasweden
19
iptvxtrasweden
Hello!
Is the sub also working on viasat movie-channels?
Lagal
Feb 5, 2017
47
sweden
smurferina
Hello!
I also want to k ow IF subs work om Viasat channels :)
jfjong
Hello!
No they don't work on Viasat movie channels, because those are dvb_teletext based. Works on most other channels, however.
But who needs subtitles anyway? :)
Lagal
Feb 5, 2017
47
sweden
smurferina
people who dont understand english? :)
i have many clients whos older that wants swedish subtitles
iptvxtrasweden
19
iptvxtrasweden
I got it work on half of the viasat movie-channels in linux-mode
thats why i asked maybe it works Better in android-mode
Skorpiz
I have a 412 box and have always been using it in portal mode .what is the difference between portal an m3u?same quick response/zapping?
do subtitles work in m3u mode for viasat?if running 412 in m3u,do you have to use kodi or similar?
thanks for all replies
Ramon Chircop
Trusted
37
ilking
How do you scroll down quickly in portal mode? When I tried it I had to go down 1 channel at a time. In m3u mode you can scroll down quickly using the P+ and P- buttons. The only problem I found in m3u mode is that you can't fast forward or rewind VODs. But I prefer to have smooth navigation. No you don't have to use Kodi or anything like that. I suggest you give it a try and find out.
Reactions: Grytfot
