Movie name: whole multi-sub VODs section
problem: no subtitles available
which map: VOD [multi-subs]
Device: STB emulator on samsung Smart tv
The same line works on GSE mobile app and also on smart iptv app.
Please advise. Thank you very much.
Movie Name: THE MARTIAN [2015]
Problem: Movie doesn't load
Wich map: VOD: VOD English
Device/App: Smart IPTV/kodi on fire tv
Movie Name: Avengers: Infinity War [2018]
Problem: ‘Video Cannot Play’
Device/App: Smart IPTV/ Sony Bravia TV
Movie Name: Every Single Movie On The List
Wich Map: English VOD
Device/App: Smart IPTV on Sony Bravia TV
Map : Multi Subtitles
movies : all
looking with smart tv
problem... cannot see which langugue it is to change
problem... every movie is skipping from time till time so I miss half the movie
Movie Name : Aile Arasinda
Problem : Black screen
Wich map: turkish
Device/App: mag254
Movie Name: All series
Problem: VOD Series folder is missing
Wich map: Series..?
Device/App: Mi Box 3 with Perfect Player app.
Movie Name: Escape Plan 2 Hades [2018]
Problem: No video, get only sound when I start the movie
Wich map: Multi Subtitles
Device/App: Mag box 254
Movie Name: Westworld s02e05
Problem: Low quality compared to otter episodes (400*700 not HD like otter episodes)
Wich map: westworld / vod series
Device/App: Apple tv4k
Movie Name: Star Wars The Last Jedi [Multi-Subs]
Wich map: VOD: Multi Subtitles
Device/App: Smart IPTV on Smart TV
Already reported it on Mai the 9th and it still isn't working!
Plays fine, might want to try re upload your m3u again and try.
Reactions: DGP
Something doesn't add up. On my smart TV it doesn't load it says video error. On mag box it loads the sound but no image. On my smartphone it works. Somethings off
Try changing the password of your line and then reuploading it on your devices. Try using a shortened URL (bit.ly for example), try changing your router on the device it doesn't work on, ...
Nothing. On a mag box Sound works but no image, on a Samsung Smart TV with Smart IPTV nothing loads and on the GSE app for Android it works..
Maybe reuploading it would work?
Seeing as it works perfectly on Android, it will be a problem for the MAGbox and Smart IPTV app. Completely reset your MAGbox, update it again and reinstall the settings, plug out your Samsung TV for 5 minutes, plug it back in and reinstall the list and see if that works.
Yes but it is the only movie that does that. Everything else works. Just set for some weeks two new mag box up and it's exactly the same.
Did you try a different TV with the MAGboxes? Could be a video format input that isn't supporter by your TV?
Yes I tried the mag box on the owners TV as well, nothing. Could you try load the movie? I can post a video if you like from the problem occurring
