S shiwen55 Member Oct 18, 2019 51 27 18 Nov 3, 2019 #1 Hi, I've heard LG is trying to remove Smart IPTV app from their content store, is it true or just roumers? Thanks
Hectorious Official Verified & Trusted Reseller May 5, 2017 1,045 2,014 213 www.rapidiptv.live Nov 3, 2019 #2 in some countries it has been remove already, but you can change language settings on your device and with some luck, you can get it back
S shiwen55 Member Oct 18, 2019 51 27 18 Nov 3, 2019 #3 Hectorious said: in some countries it has been remove already, but you can change language settings on your device and with some luck, you can get it back Click to expand... I'm in UK and I can still see that on their store. Didn't know about language setting, would it affect my aerial channels if I ever change that?
Hectorious Official Verified & Trusted Reseller May 5, 2017 1,045 2,014 213 www.rapidiptv.live Nov 3, 2019 #4 shiwen55 said: I'm in UK and I can still see that on their store. Didn't know about language setting, would it affect my aerial channels if I ever change that? Click to expand... as long as you can use and see the app, keep it running and don't change it. turn automatic updates off to be on safe side
S shiwen55 Member Oct 18, 2019 51 27 18 Nov 3, 2019 #5 Hectorious said: as long as you can use and see the app, keep it running and don't change it. turn automatic updates off to be on safe side Click to expand... I've turned off automatic updates long ago, thanks Reactions: Hectorious
Hectorious Official Verified & Trusted Reseller May 5, 2017 1,045 2,014 213 www.rapidiptv.live Nov 3, 2019 #6 shiwen55 said: I've turned off automatic updates long ago, thanks Click to expand... good choice Reactions: shiwen55
