Hello I need your help now.
I had already used some testlines and had now decided to test the line for a month.
I use on the STB VU + the Xtream TV plugin but also the Enigma2 script to import the channels.
Unfortunately, the script does not work anymore. That looks like this:
root @ vuduo2: ~ # wget -O /etc/enigma2/iptv.sh "http://tv.ldstv.iptv.uno:8080/get.p
hp? username = xxxx & password = xxxxx & type = enigma216_script & output = ts "&& chmo
d 777 /etc/enigma2/iptv.sh&&etc/enigma2/iptv.sh
Connecting to tv.ldstv.iptv.uno:8080 (104.24.19.2:8080)
root @ vuduo2: ~ #
So no station list in the VU +
Strangely enough, the plugin still works, but the dashboard always shows that the line is not being used.
Also on the FireTV Stick no channels are loaded. But that was still possible with the testline. The FireTv Stick does not have to enter a MAG address in the dashboard, I was told.
Where can the error be, I would like to use the station list in Enigma2 but also use the FireTv stick on holiday?
also like to answer in german
root @ vuduo2: ~ #
