Channel Name: All channels
Problem: No EPG, tried everything
Country: the Netherlands
Which type of device/ app: Perfect Player
Same problem
Which type of device/ app: Kodi simple ip client
Same here:
Problem: No EPG
Country: sweden
Which type of device/ app: Kod and as pvr i have both simple ip client and stalker client
A coupe Of times i had channelinfo for a very short time,stalker client crashes.
Reactions: mikenova
same problem here..
Country: Sweden
Which type of device/ app: SmartIPtv
it's quite simple their channel.ini they are using malformats the epg file.
i redid my own for Sweden and using that with Webgrabplus the EPG generated for sweden works perfectly fine.
(KODI SimpleIPTV)
(KODI SimpleIPTV)
Roniez,
Can you explain a bit better so we can make it usable as well.
Thx
Uptv smarters pro with xtreams code api: yesterday the Epg just worked without any problem, today I dont get any epg for german and french channels, all other countries are working fine. When I update ai get over 100000 new epg channel data, but I dont get it for german ones. Any ideas?
Roniez,
Thx
It was quite simple, downloaded webgrabplus ran the update to get the latest files and xml files and ini files.
Then checked the readme to read the configuration.
using dagenstv setup (from webgrabplus) it works fine for me.
Only thing i had todo was to adjust the "EPG" names so it works good.
IF on windows i can also use Perfect Player with the generated xml with the m3u file to link the EPG channels to the correct channels in the M3U.
Only needed to use the readme file and figure out how to setup the WebGrabPlus took me maybe 1hr to get it working.
So i generate data for 7days so i only have to run the WebGrabPlus.exe once a week to get a weeks worth of epg data.
Channel Name: Eurosport 1 HD SE
Problem: No EPG
Country: Sweden
Which type of device/ app: Perfect payer/Iptv Extreme Pro
Channel Name: Sky Sport Main Event FHD UK
Problem: No EPG
Country: Sweden
Reactions: Fredrik Larsson
Channel Name:
Active Family PL
Baby TV PL
CANAL+ Sport 2 HD PL
Crime & Investigation PL
Domo+ HD PL
Epic Drama PL
Eska Rock TV PL
Eska TV Extra PL
Extreme Sports HD PL
FilmBox Arthouse PL
H2 Polska HD PL
MTV Live HD PL
MTV Rocks PL
Nowa TV PL
NTL PL
Polsat Games FHD PL
Polsat Music HD PL
Polsat Rodzina FHD PL
Polsat Viasat History HD PL
Sport Klub Polska HD PL
Teletoon + HD PL
Trace Urban PL
TV Okazje PL
TVN24Bis HD PL
TVP HD PL
VH1 Polska PL
VOX Music TV PL
Water Planet PL
WPolsce.pl
Zest TV PL
Zoom TV PL
Problem: No epg
Country: Poland
Which type of device/ app: Kodi / Smart IPTV app
Reactions: zibi1978
Channel Name: All channels Sweden
Problem: No EPG, tried everything really
Country: Sweden
Which type of device/ app: TVIP s box 605 portal mode
Channel Name: All channels POLAND
Problem: No EPG
Country: POLAND
Which type of device/ app: MAG portal
Channel Name: All channels in this service
Problem: No EPG
Country: All countries
Which type of device/ app: Formuler S Mini/MyTvOnline
Log in to the dashboard. Select "Channels" -> "EPG". There you will find links to EPGs
My EPG site is empty is it normal only searchbar?
@adeeer , There is a known Mozilla problem they are trying to fix. login to your dashboard using another webbrowser like safari, explorer or chrome and then the EPG should be vissible.
Reactions: adeeer
Your welcome, I'm using Firefox myself and could for my life not understand why people said there was EPG links under channels lol. Hope they fix the Mozilla issue soon since i like Firefox.
Same thing I was trying everything :) but not different browser :).
