Gone againEPG now working on IPTV Smarters app for UK/USA channels!
Apple TV with iPlaytv app (supports only 1 EPG file right now).
Setup iplaytv with xtreme codes then you will get EPG for all countries
Yes please explainCan you explain how you do that?
Yes please explain
Create a new channel list in the app (hit the + on the very start of the app) and pick xtreme codes
server: http://yourserver (check with your reseller/dashboard) should be something like http://tv.reseller.hitv.one
username: your username
password: your password
EPG: http://yourserver/xmltv.php?username=xxxxxx&password=xxxxxxx <--- this can also be verified within the browser, just paste it and you should get a massive compiled EPG
Hmm works just fine for me and others ive helped with this setup. Probably u have typed something wrongnot working
No swedish channel info in kodi simple client
Thank You for advise i found them.Log in to the dashboard. Select "Channels" -> "EPG". There you will find links to EPGs (including the swedish).
