Does someone here use the Z7 + with a m3u file and an EPG link?
I do not get the EPG to work.
provider: cccambox.com, iptvstack and bestbuyiptv.net
There is nothing to do to get the epg work, is it maybe that you have epg but not for the country you want? not every country has epg from the portal
Why do you want to use m3u. Why not the portal its without any problems.
The m3u file i can edit so a can create special groups or is ther a other solution for that in the portal? (sorry iptv is new for me
