IPTV device make a difference on freezing problems?
mytime3
Does the IPTV device make a difference on freezing problems?
I am using firestick HD (with ethernet and wifi) and FireTV with STBEMU. Every IPTV I try gets major freezing. Can not figure out the problem. IPTV Servers,
my connection speed ( 25 Mbps ), or my device.
IPTV I tried and have freezing problems on are
1. co*****
2. imn******
3. ok****
4. be******
5. Ene******
24/7 channels freezing examples, married with children, dragonballz, starwars, etc etc, freeze every 12 seconds
porn channels freeze, the worse one is oldtimers freezers every 3 secounds others freeze every 10-12 secs
Movies freeze
I do not believe all servers would be freezing, so either connection ( 25 Mbps ) or the fire devices. Wondering if the device is the problem and if so, time to get a decent device
Reactions: BudSpencer312
Hello Dear Member,
We do Support Rapid IPTV on here,
however, my opinion is to get a better internet connection of at least 100 Mbps...
Regards @Nonid
