P Pillico71 New Member Sep 21, 2019 2 1 3 Sep 22, 2019 #1 Hi all Members, Which is the best way to install IPTV ??? either by installing a Set-Top box (MAG322WI) or Stream IPTV directly to my Smart Television, Awaiting you comments or advice. Regards :- Pillico71
Sense Well-Known Member Reseller Mar 25, 2017 629 451 113 Sweden www.sensus-tv.com Reseller ID Sense Sep 22, 2019 #2 I usually recommend going for an Android TV OS box like an Mibox S4 this way you can choose any app you like for IPTV and you dont risk the manufacture putting out firmware updates that creates blocks etc..
P Pillico71 New Member Sep 21, 2019 2 1 3 Sep 22, 2019 #3 Hi Sense, Thanks for your Response, Regards. Reactions: Sense
