As i´ve clients (322 users) on other systems with no problems.. can this problem be down to Rapid and not a box problem??
Could be, but still wierd.
When my box was crashing I got JSON script errors upon loading portal..
But I only got these errors when using the box at home. Same box, same portal, same everything on my job network had no issues..
So can't be a portal issue if it loads fine from one network but not another.. Diffrent ISPs
Never found a solution, lasted for two days then it vanished.. No problems since.
