is the box locked ?I have a Mag 254 with a USB connection at the back and I am doing all the steps but getting a 'wrong signature' message. I have tried several USB stick less than 16GB and none work, while these same ones have worked without issues on other mag boxes
Think you got it right Azole.is the box locked ?
responds to ssh? The box isn't locked as I programmed it myself a few years ago.Think you got it right Azole.
Box is locked with custom operator key.
Check if it responds to ssh.
The box isn't locked as I programmed it myself a few years ago.is the box locked ?
Then you should be able to flash it with the NoBlock fileThe box isn't locked as I programmed it myself a few years ago.
Hi,is the box locked ?
If he is doing it the right way, as I describe in my post, from System Recovery Menu, and still gets wrong signature, he has not got the original Infomir firmware to begin with but some custom made on.. Several IPTV distrubutors do this, they lock down their MAG boxes with a custom firmware, often hiding the Portal URL menu,Hi,
one of my customer gets the same when he is trying to update with the noblock file. What do you mean with "locked" in what way? Maybe you know how to unlock so that he dont gets the signatue failure?
I would test it myself but have no mag device to test it.
Thanks in advance for your help
Thanks mate for the explanation, i will check that allIf he is doing it the right way, as I describe in my post, from System Recovery Menu, and still gets wrong signature, he has not got the original Infomir firmware to begin with but some custom made on.. Several IPTV distrobutors do this, they lock down their MAG boxes with a custom firmware, often hiding the Portal URL menu,
He could try to first upgrade box from Inner portal against Infomirs update server: update.infomir.com
If this also fails with wrong signature there is no hope.. If box has a set Operator key the only one that can remove it is the one who set it or at least know the key.
Badweed, I understand the custom software, except that this is not the problem in my (maybe other's) case. I have updated many boxes and I have encountered your problem when I updated 3rd party boxes. But in this case, it is a box that I previously update that is now given an issue
What was the problem when you had Series enabled ?Mag322, Disable Vod: Series.
Its working now at my clients.
Like many others here, the Portal is not loading. All of my clients with 322 have the same problem. If i disable Series, all mag are loading portal again normaly.What was the problem when you had Series enabled ?
I'm not having any issues with MAG322 and Series enabled..
Ok, good to know !Like many others here, the Portal is not loading. All of my clients with 322 have the same problem. If i disable Series, all mag are loading portal again normaly.
