Has anyone with a MAG 322 got the 4k channels to work? Mine are with sound but without picture. Any workarounds?
Hello,Has anyone with a MAG 322 got the 4k channels to work? Mine are with sound but without picture. Any workarounds?
Mag 322 does not support 4k
i have the same Problem. it solves itselfs at your box?Update..
never mind about an answer to my problem above it's solved itself.
Hello,Hi, updated the MAG322 to the latest firmware Dec 20, the channels shifting freezes, after 2 to 3 changes of channel, rolled back to the jul 10 firmware and all is well again. Anyone having the same problem?
Cord had a 40voltage plug so think the my mag is deadWhat was the voltage shown on the plug.. The 254 has 12V 1000ma
HI.. nothing to do with the Infomir block.. It could help if you reduce the number of countries that the box loads.. Overheating problem? Make sure the box isn´t sitting on top of a heat source and that the box is ventilated.
Try booting from nand 2 if your on 1 or 1 if your on 2... pull out the mains plug, then hold down the "setup" button on remote as you plug mains plug back in,, it will give you various options... use boot from nand 1 or 2 see if that helps.
I tried all of that didn't work, for bouqet list i keep getting "there is a problem in updating bouqet list, please try again"
