Hi.. My Mag351 is not loading properly on this system ... the loading bar fills out and instead of coming to the choice of portals is loads the media browser where all the icons are mixed... Nothing happens when pressing buttons on the remote. I can only go back to loading portals..
This is only happening when i try to start Rapid.. the box loads other systems no problem.
I´ve did a works reset.. started afresh put the info needed back into the box.. No change.
Changing the DNS.. changing the pasword.. updating my bouquet.. nothing has helped..
Anyone any idee´s???
