Not sure if it's helpful: try to install the VLC player on your Android box, especially for VOD it might be helpful.Hello all! I bought a TVIP 605 yesterday and the TV channels experience is great, no lag etc. But the 4K VOD and the 1080p movies is mini stuttering. When i play the same movie through Smart IPTV on my LG TV, it runs smoothly. I've tried to change HDMI Auto Framerate to ON and it doesnt help.
Need help to solve this.. anyone with a suggestion? Did factory reset etc.
You should be able to install stb emu on android. With android you are flexibleHi! If I install Android, can i still use the mag portal?
You should be able to install stb emu on android. With android you are flexible![]()
Hello.how do u install stb emu on the box? Theres no google play app coming with the box and i tried to download apk and the box wont proceed with the installation.
Also tried with several other apk which give the same error. Has anyone tried the same or have other solution to this?
i am using linux version now with the box, but the portal which is not accepting me in, "stb blocked" but the same portal works fine with my old mag box.
if use the android version then adds the same portal it says that i need to update firmware and it's not loading the portal.
i checked with my service provider and he says that eveythings are ok
i have also tried to install stb emu from usb but its not accepting the installation. have tried with other apk and it says the same.
Hello!how do u install stb emu on the box? Theres no google play app coming with the box and i tried to download apk and the box wont proceed with the installation.
Hello!
You have ti send your mac-adress (under the box) to your reseller.
I have also tested this box in android
No problem to install tivimate
